Currenly trying to remove part of the engine mount off my Vauxhall Astra to get to the thermostat and I've hit a stumbling block by two VERY tight screws that are almost impossible to get a wrench on to.
Does anyone have any tips/tricks that might help in removing these? I really don't care what happens to the bolts, and maybe even the engine mount, but hopefully keep away from damaging engine itself.. Here are a few pictures that show the bolts in question if it helps.
They appear to be T14 in size.
Bolt 2 Bolt Third picture if necessary
Why can't you use a socket? They make them in reverse Torx just for that purpose. – ᴘᴀᴜʟsᴛᴇʀ2 Apr 4 '14 at 17:51
Because the wheel surround is very close to this side of the engine so it doesn't fit. Edit: the normal socket fits on but it gets stuck on other components, with an extension it doesnt fit – Sayse Apr 4 '14 at 17:52
Maybe I'm looking at the wrong bolts then, or it isn't obvious in the pictures. What are the details on the vehicle itself? Make/model/year? – ᴘᴀᴜʟsᴛᴇʀ2 Apr 4 '14 at 20:55
Appologies, @Paulster2 .. basically in the two pictures visible its the two very shiny bolts, they're within the timing belt surround which is slightly visible in the pictures which hinders the turning of a socket which means we need an extension to even attempt turning them but none fit due to surrounding components... The Car is a 2003 Vauxhal Astra (1.6 engine). – Sayse Apr 4 '14 at 21:18
I'm sorry, it looks from the picture that a 3/8ths ratchet with the correct socket would fit. Put a cheater on it for extra torque. Wish I was there, could help you in a flash. – ᴘᴀᴜʟsᴛᴇʀ2 Apr 4 '14 at 21:44
up vote 2 down vote accepted
obviously you tried penetrating oil.Try doing bolts up;may serve to crack any rust or paint.Failing that place a drift in centre of bolt and hit with a hammer to serve same purpose.Worst case scenario heat with an oxy torch that will expand then contract bolt making removal a cinch. CAUTION-be very aware of fuel leaks and remove battery from near proximity
In the end, I used penetrating oil which did manage to get me some leverage in removing one of the bolts.. upon doing so I found that someone had used a strong sealant to actually glue the bolt in place.. which is why neither would move. Ended up selling the car for scrap value (with explanation as to why) since the one bolt would not budge – Sayse Oct 31 '14 at 8:02
