Sign up ×
The right hand side blinkers in my 2005 Holden/Opel Barina stopped working. When I turn the blinkers on they do the right click-click sound just much faster than usual. All 3 blinkers stopped working. I've checked the front and rear bulbs and are good. I've checked the fuse and it's good. I've measured the voltage on the metal contacts at the back and there is no voltage at all.
Where should I start looking for the problem?
4 Answers 4
If the bulbs are good, the fuses are good (both in the engine compartment and inside the vehicle, and the flasher is good (the clicking sound maker), then I would say the turn signal switch. However, to properly diagnosis that, you will want to get a wiring diagram.
Other, less likely items would be a bad ground, bad wiring, or bad connection somewhere.
One other thing to check is to see if one of the smaller turn signal bulbs are out. When any of the bulbs are out, the turn signal will blink faster. You may have one or more marker lights on the side of the car which function as a turn signal light. If out, this could be your problem.
Simple test to narrow it down a bit - do the three bulbs light when you put the hazard-warning lights on?
If so, my first culprit would be the switch, and if not, a wiring fault...
Apparently the Barina has two different flashers (relays) one for each side that are installed behind the batter compartment in the most inaccessible place possible. One of these relays was broken. Had to buy another one and replace it and they are all working now. The clicking noise is done by some other component from what I see as it was clicking nicely and even the lights on the dashboard were blinking correctly.
