Take the 2-minute tour ×
I've seen photographs of cars with strange inclined tires like the one in the picture I pasted here. They seems to be Japanese cars. Is it for drifting? Maybe for appearance? Do the tires get injuries? enter image description here
Where we're going, we don't need roads! zooms off into the clouds –  Nick Mar 26 '14 at 14:33
Because people are stupid. –  Juann Strauss Apr 24 at 7:15
5 Answers 5
up vote 5 down vote accepted
In this specific example the car is more than likely using airbags. When you decrease or increase the height of a car it affects the tire alignment by usually causing positive camber, pushing the top of the tires outward, this is a highly modified suspension system.
This particular person has modified their suspension so the top of the tires tuck in when the airbags deflate so they don't hit the fender well. Which not possible with a dual wishbone configuration, so more than likely its a basic strut assembly.
Most people will adjust their cars for negative camber, this way during hard cornering when the tire deforms on the vertical axis you get the largest amount of rubber on the road. Most tuners overdo this past performance and into the realm of looking good.
The tilt of the wheel is known as the camber angle. Tilting the wheel in that manner is called negative camber. Doing it the other way around (top outwards) is positive camber.
Mounting the wheel with a negative camber improves grip under hard cornering as it counteracts rolling. On a completely level tire (0 camber), when a horizontal force is applied to the rubber, it rolls, causing the inner edge of the contact patch on the outer wheel (and the outer edge on the inner wheel) to lift, reducing the size of the contact patch, and subsequently grip. By tilting the tire inwards, this is counteracted, but at the cost of a reduced contact patch when driving in a straight line. It's a tradeoff and requires careful modelling and testing to determine the optimal camber angle for a given vehicle.
Some F1 cars utilize variable camber systems, allowing the camber angle to be adjusted on the fly, giving ~0 camber on the straights and proper amounts (again, determined by careful modelling and testing) of positive/negative camber when turning.
That extreme amount of camber on the car you showed is purely stylistic and would be horrible for both tire wear and handling, but lesser amounts of camber are common. For example, the negative camber angle is plainly visible on the wheels of this Ferrari F1 car.
image of a Ferrari F1 car displaying negative camber
If you're only turning in one direction (i.e. oval racing), you can further optimize by applying both positive and negative camber to the inner and outer wheels respectively, countering the rolling on both wheels, giving you maximum grip when cornering. This is pretty much ubiquitous in NASCAR.
Image displaying positive and negative camber on a NASCAR car
It is entirely for style.
This is called "camber".
The tires will wear in an odd manner. The tire contact with the road is usually a rectangle on the bottom of the tire. This extreme camber makes the contact patch very small and near the inside edge of the tire. This does significantly reduce grip.
The question assumes that the car is a drivable configuration, which may not be true. This car and similar photos you have seen probably have Height adjustable suspension this allows the ride height of the car to be changed on demand.
In all likelihood the frame of the car pictured is sitting on the ground. The suspension has been lowered (or tires raised) through a powered operator controlled method, until the tires are no longer supporting the car. There are several variables, but as you can see in the question image, the tires on the vehicle will not clear the body panels without being tipped in for the current ride height.
Alternatively @Freiheit has a good explanation also. A search for images on Google finds some images of vehicles that appear to be moving with similar extreme camber.
Because people are stupid. It's simply for the look or maybe to get the car even closer to the ground when the wheels are too tall. There is no practical reason to do so and if you tried to drive such a car, you will probably die in a horrible accident because you won't get any grip.
Insulting peoples personal taste in style does not contribute to the community. These cars are usually trailered, and only running such massive amounts of negative camber when the air bags are deflated. This car in particular looks to be completely on the ground. –  Chris Mar 26 '14 at 14:46
Have you ever been to Dubai? People actually drive them like this. –  Juann Strauss Mar 27 '14 at 8:09
