Not a long time ago, I went to the service for an annual technical inspection. They replaced the front-right leg of a stabilizer. And gave me the previous one back. I wasn't too smart to ask the reason, since I'm not familiar with internal parts of my car.
As I can see - it's just a metal stick with two moving parts on its ends:
Original part
So, the question is - what can be wrong with this "thing"? How can I check it on my own detail?
P.S. The photo above is not mine. If it helps, I can make a photo of my detail.
Update #1
This is the part from KIA Rio (year 2011). And it should be mounted this way:
If you add the make, model and year of your car, it will help us put answers in better context. – Bob Cross Feb 10 '14 at 13:54
@BobCross I've updated the question. – abyss.7 Feb 10 '14 at 14:23
Added a second edit to explain what this part is, it's purpose, and how to check to see if it's worn out. – Pᴀᴜʟsᴛᴇʀ2 Feb 10 '14 at 15:19
I just noticed "it's just a metal stick with two moving parts on its ends" - yes, that describes almost every really important part of the car :-) – Bob Cross Feb 13 '14 at 13:39
up vote 2 down vote accepted
tl;dr: The stabilizer works with the swaybar to reduce body roll in turns. The stabilizer in the picture is missing a nut on the top bolt.
The picture in the question clearly illustrates the function of the stabilizer (if you know what it's connected to) and what some of the failure modes might be.
Here is a picture of some of the critical components that are not immediately obvious from your snapshot:
Illustration of the swaybar and stabilizer on a Kia Rio Source: www.kiapartsoverstock.com
As you can see, there is a stabilizer on either end of a piece of metal that looks like a pipe with two question marks on either end. That's the swaybar (AKA anti-roll bar): it acts as a torsion spring. If you push up on one bendy end, the bar will rotate in those bushings, lifting whatever's connected on the other side. However, if you try to twist the bar by inducing body roll in a turn, it will strongly resist, keeping the car more upright.
NOTE: I'm trying to avoid a wall of words answer so please see the link for a more detailed explanation of the basics, pros and cons of swaybars. Also, look closely at the diagram and the picture in the question: there's a nut missing from that top bolt!
As you can see from your picture, the stabilizer is what connects this swaybar to the moving parts of the suspension (in this case, the strut assembly on the left of the image that heads up to the top). It transfers that vertical motion down to the swaybar. The swaybar then twists as noted above. This twisting vs. pushing-pulling is why the stabilizer has those rubber bushings at either end.
So, given all that, why would you replace a stabilizer?
  1. Rust: accursed rust nevers sleeps.
  2. Worn bushings: as they wear, they will grip the connecting bolts less tightly. This wear will progress until you'll start to hear rattles and clunks as the stabilizer loads and unloads. Eventually, the bushings can fail, pulling the connecting bolts completely loose.
  3. Broken pieces: if those bolts break loose, the stabilizer isn't much use.
They're also considered "bad" if there's any slop in them. They will wear over time. If they get real bad you'll hear a clunking as they unload. – Brian Knoblauch Feb 10 '14 at 19:57
@BrianKnoblauch, yes, that's a much better initial symptom. Pulling out is the end state rather than the initial finding. – Bob Cross Feb 11 '14 at 12:48
Since I don't know exactly where this piece goes in the front end of your car, I will give you some generalities of why this piece is built as it is and why it probably needed to be changed.
The front end of your car has a lot of things going on. Way back when, vehicle front suspensions were setup with a straight axle, somewhat like what rear-ends are setup today, only they had what was called kingpins to allow the front tires to articulate. It may have looked something like this:
In the picture, there are springs which support the axle, then at the outer ends of the axle you see the spindles (the pointy thing sticking out at you). What allows this to articulate is the kingpin. You had to have some type of articulation to allow the wheels to point and this was it. Along with this, there also had to be some way for the input the drive applied to the steering wheel to be translated out to the spindle in order to get the vehicle pointed in the correct direction. For this, you need (obviously) the steering wheel, which gives the initial input. Then you have the steering column which transmits the effort from the steering wheel to the steering box. The steering box changes the direction of effort, as well as reduces the steering ratio so as to make steering the vehicle easier (way back when there wasn't any power steering, other than "arm strong" power steering). On the steering box, there is an arm which is attached to linkages which ultimately goes to connection points on the spindles which causes the front wheels to turn. This long explanation is a general description of the steering. The reason why this is important is because this type of front end does not make for a comfortable ride. It is bouncy and very harsh. It was, however, very tough. It would stand up to a lot of abuse.
This leads us to the part you are showing above. Engineers figured out a way create a two point system which allowed the each front end to articulate independently from each other, giving the occupants of the vehicle a much more enjoyable ride as well as better cornering performance and adjustability. How the did this was by introducing items called ball joints. These ball joints are like what are at the end of your rod. They are very stiff, as in they do not give much deflection, but they do allow for articulation.
Here is a crude representation of an independent front suspension:
The points where it says "upper" and "lower" are where the ball joints are at. If you draw a line through these, this is where the front spindle articulates and replaces the kingpin.
Your piece above helps in this type of endeavor by providing areas of movement or articulation, but do so without deflection (movement is articulated without any give, so is exact). The probable reason your piece needed replaced probably had to do with one or both ends of the rod being worn out ... it has give. This makes it so your steering input is not as accurate, so your vehicle does not track correctly, so you wear your tires out before their time, and so you don't get as good of gas mileage. It can also cause safety issues with your vehicle while driving, as you will not have as great of control of the vehicle.
EDIT: (I realized I did not answer one of your questions)
To check to see if one of these rod ends or ball joints is worn out, depends on where it is at in the suspension system. The first thing to check for are cracked and/or split grease cones (rubber part which protects the joint). If these are bad, it let's moisture and dirt in which quickly wastes the joint away. Tie rod ends (connection at the steering knuckle/spindle) are checked most easily in a two man operation, one sitting at the steering wheel the other looking at the end. Have the person sitting at the wheel turn it slightly (5deg either way is probably enough). The tire should move with the turn of the wheel. If there is deflection at the joint, it is going bad and will soon need replaced. Ball joints are a little more complicated. The easiest and surest way I have seen to check them is to jack one side of the vehicle up at the ball joint of the lower A-arm (second picture) so the tire is about 2-3" off the ground. Get some type of lever (long 2x4) and from the front of the car, place it under the tire with about 5-6" sticking out the other side (toward the back of the vehicle). While applying pressure up slightly on the tire, wiggle the board back and forth while looking for any movement at the ball joint and A-arm assembly. If there is movement, it needs replaced. When I say movement, I mean the knuckle/spindle is moving but the A-arm is not. This is not the only way to check this, but is one of the best/surest ways I have seen to do so.
There are other methods for other joints. If you have a specific joint, I can probably help you with a way to check it.
Hopefully this helps with your understanding of what the piece is, how it works, and why it needed replaced.
EDIT 2:
From your picture, the link you are showing on your vehicle attaches the body to the front sway bar. As the name implies, the sway bar helps to keep the vehicle from rolling during cornering (keeps it level). It does this by tying the two sides together (both lower A-arms), trying to get them to move together. It acts like a torsion spring in this aspect. This is directly responsible for the stability and safety of the vehicle during driving. The joint on either end of the rod allows the A-arm to move up and down without binding, but it also does this without give. With this part being worn out, it can cause other parts to wear out faster, such as the springs, shocks, tires, and other ball joints. To check this particular part out, you would do three things. First, look at the boots (as mentioned before) to see if they are cracked and abused. This is a precursor to being worn out. It shows there is quite a bit of movement around the joint itself. Secondly, you should just be able to grab the rod and twist it. If this is fairly easy to do, it's probably worn out. Thirdly, if you grab it securely and jerk it back and forth, you should not have any movement at the joints. This is a SURE sign the joint is worn out. You may want to grab it near the joint and try each end separately. On this type of link, if either end is worn out, the whole link needs to be replaced.
Thanks for the answer! Right now I'm trying to understand what you wrote - and how it applies to my car and to my part. – abyss.7 Feb 10 '14 at 14:31
Check the updated question - @abyss.7 has added picture of part in question, make, model and year. – Bob Cross Feb 10 '14 at 14:52
@BobCross ... thanks for pointing this out. – Pᴀᴜʟsᴛᴇʀ2 Feb 10 '14 at 15:20
