Take the 2-minute tour ×
I have a 2009 toyota corolla 1.8l. It made a poof sound and died. Now it will not start. The ignition stays engaged unless I turn it off. I have had the starter checked and replaced, the ignition cylinder, and the ignition switch. I just replaced the starter relay and the same pfoblem still exists. What could it be?
Not sure I understand what is happening. I take it was started and running when it went "poof"? Or were you trying to start it when it did this? Are there any codes (check engine light)? Could you explain what you mean by "the ignition stays engaged? Do you mean the starter stays engaged when trying to start it or what? –  Paulster2 Feb 7 at 0:10
add comment
