My car heater started acting up. It would heat, then no heat. So I put a new thermostat in, had the heater core flushed, and new coolant added. The other day after this, it got so hot it shut down. I had it towed, they changed oil, and put another thermostat in, but it is still doing same thing. Help, very low funding.
When you say, "it is still doing same thing" ... do you mean it is overheating and shutting down, or the heater will blow hot/cold? There appears to be multiple questions here, though they are related. – Pᴀᴜʟsᴛᴇʀ2 Jan 9 '14 at 14:54
Did you checked that ventilator is working if hot? Is the water pump and its belt are healthy? – user1126070 Jan 10 '14 at 16:53
Did you check your vacuum lines, IDK about your specific vehicle, but on some cars the climate control is powered by vacuum and a vacuum leak will cause them to operate/fail intermittently based on engine load. – Jrican Oct 16 '15 at 5:10
Your initial approach was solid: New thermostat followed by a flush/fill.
....another simple thing you can try is replacing your radiator cap. Old radiator caps have seal erosion won't hold pressure, slowly leak coolant, and then once the coolant gets low, you'll get these symptoms--slow to heat and wild temp fluctuations.
So I think the only cheap thing left for you to try is replacing the radiator cap.
Also, you might check your coolant level a couple days (or even several hours) after you last top off the reservoir and run the engine. I've heard of radiators "burping", where it seems like they're full, then after the car runs for awhile, it's like "oh wait, but now it'll accept more coolant??" So this is just to be prudent make sure you're really starting with a full radiator.
If neither of those two tips gets you going, unfortunately this could mean a failing water pump. :/
Oh... as for @user1126070's question about your belt ..are you hearing any belt squeals, either on startup or when accelerating? – elrobis Jul 22 '14 at 18:34
@Катерина ..I was talking about the radiator and coolant system, not the engine oil. That should have been pretty obvious. – elrobis Dec 15 '15 at 15:36
