I ride a Honda Rebel 250 motorcycle and over the past few days I find that the bike is losing power when accelerating fast.
When I twist the throttle to accelerate quickly (in any gear) I hear the engine sound increasing in pitch by a lot more than I'm used to hearing, but the motorcycle doesn't seem to respond and performance is very poor. If I then twist it back to a position of slow acceleration, the engine noise returns to I'm used to hearing (still the accelerating noise but a lot lower pitch) and the performance also seems to be appropriate to that level of acceleration.
What could be wrong with the motorcycle?
I am having the same issue, I have a 125cc ajs regal raptor, and if I am accelerating in well its mainly 4th gear and going up a slight incline it'll lose power and even if I knock it down into 3rd it'll struggle, but I think I may have a block in the air fliter or in the carbs, so it needs sorting, just something to think about next time you have a similer problem mate – user3632 Sep 3 '13 at 20:25
@AdamRobinson the key here is that the RPMs increase without the motorcycle accelerating. This is the hallmark of a slipping clutch, and could not be explained by blocked air filter or carb issues. – mac Sep 4 '13 at 15:49
up vote 15 down vote accepted
My knowledge of motorcycles is limited so I could be wrong, but it sounds like the clutch is slipping.
I've had a mechanic look into it and yes, the problem was the clutch slipping. – Paulo Pinto May 16 '11 at 21:17
Did he say why? Is it just worn out, or something to do with the oil? – theUg May 25 '12 at 4:20
The clutch plates were worn out. – Paulo Pinto Nov 15 '12 at 17:34
Do you tend to ride with your hand on the clutch lever? if theres no play on the clutch lever you could accidentally be causing wear by keeping it slightly "on" – Mauro Mar 8 '13 at 8:18
I realize this question has been answered, but keep in mind that any carbureted engine can bog down under throttle and cause a lack of acceleration.
If it can be backed off and regain acceleration, then I'd suggest carb tuning. If the engine revs, but no acceleration then it's a slipping clutch.
protected by Zaid Aug 26 '15 at 15:04
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site.
