I'm experiencing loss of electrical power to my Mk5 Golf. It seems to happen mostly when the car hasn't been run for two or three days.
We changed the battery a few months ago. More recently, there was a loss of power and the car wouldn't start. We'd diagnosed it as the alternator, which was replaced. This worked fine for a week or so, but I'm now at the problem where I'm experiencing loss of electrical power - car sounds uncertain about starting, clock is reset etc. There's still some power, because the radio, lights and clock etc still operate, even if the car doesn't start.
The remote locking feature only half works, too. I can lock remotely, but I can't unlock remotely - I have to use the key. The fob has started to show a red light when the unlock button is pressed.
I'm assuming the electrical power is being lost somewhere else. I'd previously checked for doors not shutting properly or anything else I could think of that might leave a light on, but there was nothing to suggest that was happening.
So how might I start to diagnose how the car is losing electrical power? I'm completely stumped.
If you run the vehicle on a regular basis (daily), I take it you don't experience the issue? Or does this happen every day when you go to start it in the morning? – Pᴀᴜʟsᴛᴇʀ2 Dec 17 '13 at 15:22
It's less of an issue. It might sound like it struggles to turn over for a few seconds, but it eventually starts. Other times it will start normally. So I try to start it every day at the moment, even if I'm not going anywhere. – James Dec 17 '13 at 19:23
up vote 4 down vote accepted
The fault you describe appears to be a simple matter of 'parasitic drain' on the battery.
Disconnect the battery earth terminal, connect a ampmeter between the cable and the battery post. Run the ampmeter to outside of the bonnet and close the bonnet without trapping the ampmeter wires. Make sure all doors are closed, they do not have to be locked. After about 10 minutes, check the amp reading.
After around ten minutes all modules will go to 'sleep'. The ampmeter reading should now be at about 0.03 amps to 0.5 amp max. The doors must be closed as opening the doors activates the initial operation of the fuel pump, the bonnet being open activates isolation of the windscreen wipers. Both of these mean the vehicle will not go to sleep.
If the ampmeter shows a high reading, you must now systematically disconnect circuits until the amps drop off. One way is to disconnect one fuse at a time, check the ampmeter. If it has now dropped, that is the circuit that is causing the drain. Rectify as necessary. If the amps do not drop replace the fuse and then disconnect the next fuse. Repeat the procedure to find the drain. If you have none standard accessories, such as amplifiers, the disconnecting routine should start with these.
Finally, even if a battery or a replacement alternator are new there is an outside chance that they may be defective and this should be borne in mind.
It's also possible to test the current directly across the blade-type fuses, without disconnecting the battery. They have probing terminals on top. Doing that could help you find the troublesome circuit faster. It's demonstrated in this video from Motor Age magazine: youtube.com/watch?v=P-wxG6U5TuY – Josh Caswell Dec 17 '13 at 19:18
Thanks for your answer, Allan. Is that likely to also be causing an issue with my central locking? I forgot to mention that the central locking issue only came about a few days after replacing the alternator (but wasn't a problem before then, even when the car wouldn't start). I've seen lots of central locking-related reasons for seeing the fob's red light flash, so I'm unsure if it's related to what you call 'parasitic drain' or there's a coincidental issue with the central locking (which would be just my luck!). – James Dec 17 '13 at 19:28
@James ... I don't know about your car specifically, but wonder if when you replaced the battery/alternator if it reset setting back from what it is now. Wondering if the way you had it may be a user preference and was reset back to standard. Something to check your owners manual about. And if nothing else, something to eliminate by checking to see if this is an actuality. – Pᴀᴜʟsᴛᴇʀ2 Dec 17 '13 at 20:02
Good video. Measuring acoss the fuse for a volt drop when you are looking for a current of maybe 1 to 2 amp is not as good as an ampmeter in series though. – Allan Osborne Dec 17 '13 at 20:55
You can have a drain on the central locking just as any other circuits. The later MK IV have a sealed door setup. This is because the door body is used as part of pressure sensor setup for side impacts. To get to the locks will mean a new door skin and repaint. – Allan Osborne Dec 17 '13 at 20:59
