I know that water behaves strangely once the temperature drops below 4 (celsius) degrees. In a nutshell, its volume starts to expand (see wiki for further details) below 4 degrees - when temperature reaches zero it freezes. Again, as far as I know and understand, this anomaly has only to do with the density of the water - ice forms when temperature reaches zero.
So my question why in many (all?) cars the temperature display starts to blink (sometimes also give sound warning) when the temperature reaches 4 degrees? Is it just a general warning that it is cold, or does it have to do with some properties of the water?
When the temperature is 0 Celsius, ice is likely to be visible and drivers will be aware. Typically they will be driving carefully, and may even be on winter tyres.
Where the temperature is falling through 4 degrees, most road conditions will be fine, but there may be parts of roads (eg in the shade) that are at 0 or below and could be icy. The risk here is that the driver who isn't expecting ice may be driving at a speed which is dangerous when they hit an ice patch. This is the cause of a lot of accidents - the surprise black ice on a shady corner.
I don't know why it is 4 degrees rather than 3 or 5, but the core premise makes a lot of sense. Twice I have been on a long overnight drive (over 8 hours) and making good progress when the ice alarm has alerted me, so I have dropped my speed by a significant fraction before reaching a potentially dangerous skid.
The outside air temperature sensor is often located in a part of the vehicle that will receive some warmth from the engine in certain parts of the operating envelope. Reading as much as 5 degrees high is something it may do. When it's indicating 4 degrees, it warns you because the actual temperature may well be below freezing.
The Low Temperature Warning is activated because the sensed ambient temperature is low. The sensor will not know whether the ambient temperature is warming up or getting colder. It will not take into account any 'wind chill' factor making any temperature effect lower.
When the LTS is on it means there is a high probability of ice on the roads. Drive carefully and reduce your speed in anticipation of ice.
