I've always heard that the oil in a car should be changed every 3000 miles, but I read the manufacturer's suggested maintenance guide, and it says to change it every 5000 miles. Which is correct, or is it something entirely different, and why?
closed as off topic by Joel Spolsky Mar 8 '11 at 4:07
Questions on Motor Vehicle Maintenance & Repair Stack Exchange are expected to relate to motor vehicle maintenance or repair within the scope defined by the community. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about reopening questions here.If this question can be reworded to fit the rules in the help center, please edit the question.
What does the vehicle's manufacturer recommend? There is no one answer that applies across the board. – John Gardeniers Mar 8 '11 at 1:19
As the question says, the manufacturer's maintenance guide says 5000 miles. – PearsonArtPhoto Mar 8 '11 at 1:22
Not a pro question. Please see this – Joel Spolsky Mar 8 '11 at 4:07
up vote 7 down vote accepted
If you're looking to change oil at a set mileage interval you should use the maintenance interval set by the vehicle manufacturer. More frequent changes aren't necessary however you may wish to change oil more frequently based on driving conditions (lot's of stop & go, short drives.)
