I have a BMW E90 2007 with a M47TU2 engine, Can anyone tell me where the EGR valve is?
How to get it off, howto clean it and what cleaning materials are required.
Thanks
BMW use valve overlap to serve EGR. Most if not all of BMW engines DO NOT have an EGR valve. They use a system on the engine that they have named VANOS. This system changes the cam shaft timing so that it allows exhaust gas to remain in the cylinder during the inlet stroke. This has the same effect as an EGR system. www.bimmerforums.co.uk has a very good and detailed explanation.
this is a Q & A, it serves no use if people tell you to search for something... If someone is googling the question I asked, they'll come here and get a non-helpful answer and go elsewhere.. – Michael Baldry Nov 19 '13 at 7:52
Also, your answer doesn't answer any of my specific questions 1) where is it located 2) how do you get it off 3) what is best to clean it with – Michael Baldry Nov 19 '13 at 7:53
BMW, most if not all engines DO NOT have an EGR valve. They use a system on the engine that they have named Vaneos. This system changes the cam shaft timing so that it allows exhaust gas to remain in the cylinder during the inlet stroke. This has the same effect as an EGR system. www.bimmerforums.co.uk has a very good and detailed explanation. – Allan Osborne Nov 19 '13 at 18:18
Thats a better answer :) Can you edit your original and I'll accept it – Michael Baldry Nov 19 '13 at 20:26
Location
It's located between your throttle body and the manifold. You would remove the air intake and the throttle body from the manifold to best accesss the EGR and clean it.
Video
Here is a youtube video cleaning of an EGR (exhaust gas re-circulation) valve that is a similar model to yours.
Supplies
To clean the valve you will want
  • carb/brake cleaner to break down the carbon and unburnt hydro-carbons
  • small wire/nylon brush
  • oil picks and what not.
  • One can of B-12 Carb cleaner
Hope this helpful. Best of luck.
As Allan mentioned, this engine does not have an EGR valve.
You might find these parts diagrams helpful: http://www.realoem.com/bmw/partgrp.do?model=VC11&mospid=48821&hg=11
if you want to delete EGR best would be to search this forum, you could find usefull info there. I hope it helps.
Boris
Another usefull info can be found in this forum. – Mustafa105 Apr 7 '14 at 7:31
