I think I have a leak in my radiator because water came pouring out from under my car mazda 6s 2002. The only thing is when I opened my coolant cap it was still full. What could be the problem?
Can you tell from the liquid on the ground if it was antifreeze? Any evidence of steam? Any chance it was windshield solvent or from a/c condensation. – mikes Oct 15 '13 at 23:53
Did you check when the Engine was hot or after allowing it to cool for sometime ? – user3844 Oct 16 '13 at 14:52
Did you check the radiator itself, or the overflow tank? If you lost coolant through a leak, the overflow would not be a good indicator of the level. You would need to check the pressurized system--after it's cooled off and no longer pressurized! – Nick Oct 16 '13 at 15:17
Was the A/C running prior to this? It could be condensation from the A/C. Coolant tends to be pretty green and smelly so you'd have little trouble mistaking it for water.
The other option, as mentioned by mikes, is that you have a hole in your windshield cleaner bottle.
Coolant or windshield cleaner will have distinctive colors and smells: you might want to suggest those as well. – Bob Cross Oct 21 '13 at 12:07
yeah, but windshield cleaner could be mistaken for water. sometimes it even is water. – vlsd Oct 21 '13 at 17:34
