I bought a pair of side marker lamps for my car (OEM p/n 26160-JK00B). They are compatible with Nissan MO/Infinity. Front view Connector view enter image description here
My car is a Nissan Murano 2009 (US model) which doesn't come by default with these flashers so I have to install them by myself.
The original headlamp harness doesn't come with connectors for these side marker lamps so I have to wire myself this thing (a wire extension from the front headlight - the turn lamp - to this side marker lamp).
But the question is: what connector should I buy/use in order to connect this lamp properly? Of course I can crimp two female spade connectors and then to hook them to the lamp but I would opt for a waterproof connector that fits, if possible.
Maybe someone, a handy auto electrician - anyone, has a clue about what could possible fit into that socket.
Cut one off a junkyard car. – geoO May 9 '15 at 17:45
You will be able to get the pigtail from the dealer. It's the connector and about 12 inches of wire. They are used to repair harnesses.
Lol, I had forgot about this post :-) I figured out finally what connector I needed: Z03FBR manufactured by Mitsubishi. I was able to find them in Japan at this seller: http://www.best-sys.com/products/detail.php?product_id=92
The website is only in Japanese so knowing little bit of kanji would help :-)
So I bought the parts separately (the female, the male, the housing) then I just used some wire I already had at home and I manufactured the whole assembly myself.
PS: they could be found probably at any Nissan dealer in US (eg. courtesyparts.com)
