Take the 2-minute tour ×
I recently purchased a 2013 Lexus RX450H and when it came time to do the 5,000 mile service, a leak was detected of the oil from the oil pan. Further investigation revealed that at the factory there is a seal applied to the oil pan and in our car's case, the seal was not completed all the way around the pan. The repair to this was to instead use a gasket to seal the oil pan.
My concern is that the original factor seal was defective and that potentially using a gasket instead may provide a seal that is inferior to the normal factor seal were it properly applied. Is my concern valid? Does using a gasket to seal the oil pan provide an inferior solution to the factory seal method that is likely to fail sooner? Should I require Lexus to warrant the gasket to last as long as the original factor seal would last? Is this a common problem? Should I be concerned?
add comment
1 Answer
up vote 3 down vote accepted
Was the factory solution not using a gasket?
A gasket is usually better than the Room Temperature Vulcanizing (RTV) sealing method since RTV is really messy and hard to clean off during maintenance and is harder to apply which may lead to failure as you have seen.
There should be no need to warranty the gasket. If it becomes an issue again it should still be under your vehicle warranty.
I'm not familiar with that exact model, but my Toyota/Lexus experience with other models is that they don't use gaskets for oil pans from the factory. It just uses a bead of sealant. –  Brian Knoblauch Oct 1 '13 at 19:26
It's RTV then which kind of sucks honestly but I guess it is cheap and easy for a machine to squirt on. –  Mike Saull Oct 2 '13 at 16:10
@BrianKnoblauch Please define RTV, thanks! –  WilliamKF Oct 2 '13 at 23:42
@WilliamKF It stands for Room Temperature Vulcanizing which is a type of sealing material that hardens at room temperature and is used to seal things like a gasket does. –  Mike Saull Oct 3 '13 at 4:02
add comment
