I am a new driver and need to change oil. I have following options. Which one should I select?
My car: Toyota Camry 1994 LE, 4 cyl, 127000 miles.
NTB: $19.99 It includes following services:
  1. Tire Rotation
  2. TPMS Reset where applicable
  3. Battery Check
  4. Belts and Hoses Check
  5. Brakes Check
  6. Fluids Top Off
Jiffy Lube: $30 It includes the following services:
  1. Brake fluid level (in transparent reservoirs)
  2. Serpentine belts
  3. Wiper blades
  4. Antifreeze/coolant reservoir levels
  5. Engine air filtration system
  6. Exterior lights
  7. Chassis (lubricate when applicable)
  8. Tire pressure
  9. Transmission/transaxle fluid
  10. Differential fluid
  11. Transfer case fluid
  12. Power steering fluid
  13. Windshield washer fluid
  14. Battery water (excluding sealed batteries)
  15. Exterior windows
  16. Vacuum interior floors
Firestone $21 enter image description here
closed as off-topic by Mark Johnson Oct 7 '13 at 16:34
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions seeking price-shopping assistance are off-topic because they tend to become obsolete quickly. Instead, describe your situation and the specific problem you're trying to solve." – Mark Johnson
If this question can be reworded to fit the rules in the help center, please edit the question.
up vote 0 down vote accepted
NTB or Firestone... or... D.I.Y. for price of motor oil - Priceless.
Cost of 4 quarts of oil is approx. $15-$25, depending on quality, plus the filter means the rest of the time they spend on checking all the other fluids and wear parts is their way to find and upsell more work. Have them show you all the things they check and what they are looking for, and then you can do that yourself in the future.
