Sign up ×
Assuming that an engine always has enough oil to be lubricated properly but burns quite a bit of oil, can it cause any damage in long-term because it doesn't belong to the combustion chamber?
I have a 2005 Subaru 2.5 RS. The engine is known to have quite a few issues including failing head gaskets and piston ring lands. The head gaskets on mine were replaced not so long ago. However, I'm burning about 1L of oil every 1,000 kilometers. I'm the type of guy who checks his oil level very often and I don't mind to add oil. Getting those ring lands replaced is not a maintenance I can afford right now.
I've noticed that the oil filter has a small leak on it, probably because it was over-tightened. However, I don't think that I would lose that much oil because of that.
I'm strictly concerned about the motor. I know excessive oil burning can end up in a clogged catalytic converter.
Burning oil can cause fouled spark plugs, which can eventually lead to misfires.
Burning oil could also potentially lead to valve issues if enough oil builds up. I'd imagine exhaust valves would be most susceptible.
Your owner's manual may list an "acceptable" level of oil consumption, which could help you gauge how bad your condition is relative to what the manufacturer thinks is OK.
