I'm going to be rebuilding my clutch slave cylinder (new spring and piston). The fellow at the parts counter mentioned that I should use the finest possible hone when cleaning up the inside.
I looked into the process of cylinder honing and it seems that, for engine cylinders, it's important to get a cross-hatched pattern of "micro-scratches" that are at a 45˚ angle from the cylinder's vertical. This is supposed to support the oil and keep the rings well-lubed. If that is true, then given the different fluid and much lower speed and repetitions of the clutch piston, does it apply to the clutch cylinder too, or can I just give the inside a good general roughing-up?
up vote 2 down vote accepted
The honing of an engine cylinder is done to help the piston rings bed in - the 45 degree angle of the honing and the 90 degree angle of the ring edge wear against each other and create a much tigher tolerance.
You don't need this effect in a clutch cylinder, in fact it would be detrimental as you have a rubber seal rather than a steel ring. I would have thought that you'd want the bore to be as smooth as possible to avoid anything that might snag on the seal and damage it.
This makes perfect sense, and is consistent with the advice I was already given. I wasn't actually aware that combustion cylinder rings were steel (although I had wondered how rubber could possibly work) -- I haven't gotten that deep into my engine yet. – Josh Caswell Aug 9 '13 at 19:23
