I have put in an aftermarket stereo into my car. (Pioneer DEH-4500BT).
I hooked it all up ok and it was all working. However i noticed that it did not turn off with the engine.
Before i had brought it i had read up about changing stereos so i knew what this was.
I got a friend of mine to wire the Cigarette lighter to the "Switched 12v".
Now it turns on and off with the car.
However, when i turn off the car and leave it for about 30 minutes, the radio stations that i have saved disappear.
Is there any way to fix this?
The car is a Citroen C3 - 1.1i Petrol - 2004 (04).
PS. My friend is a Car Electrical Specialist, but has gone on holiday for a month today!! He also checked correctly which one was permanent live and which was switched live.
You need to make sure that the head-unit is hooked up to constant power (usually the yellow wire on the harness). Make sure that it isn't hooked to a circuit that goes off after half an hour or when you open the door.
Exactly, you need to get a constant power to keep the memory between each shutdown/start-up. The constant power wire will draw really few amps that will not drain your battery. – Gabriel Mongeon Jul 29 '13 at 18:30
Some cars don't have a "constant power wire in the audio system loom. I had the same thing with my Opel Corsa. The guys who installed the system had to run a new wire from somewhere. – Juann Strauss Jul 30 '13 at 7:47
It is all wired correctly. The constant and the switched were both tested with a volt meter to check which ones were which – Dr.Pepper Jul 30 '13 at 9:52
@Dr.Pepper chances are that the constant power isn't actually a constant power. Maybe a 30 minute power. Where are you getting the lead from a random loom or fuse box? – Mike Saull Jul 30 '13 at 13:21
hi mate, the switched 12v is coming from the cigarrette lighter and the constant is coming from the original loom with a harness on the end which came with radio – Dr.Pepper Jul 30 '13 at 19:17
From the manual:
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-X6500BT_OwnersManual112712.pdf
Black to Ground
Yellow to "always on" (battery, fuse protected) {saves memory}
Red to ignition
Blue/White to external amplifier (or insulated)
Orange (optional) to park lights
It is all wired correctly. The constant and the switched were both tested with a volt meter to check which ones were which – Dr.Pepper Jul 30 '13 at 9:51
If, after half an hour or so, the yellow wire is still at 12V (or better) and the radio ground is solidly connected, I'd suspect a faulty radio. Let us know!! :) – JoeFromOzarks Jul 30 '13 at 16:05
im gonna get the volt meter out and have a check i think at some point lol – Dr.Pepper Jul 30 '13 at 19:18
I'd be grabbing the voltmeter about the second or third time I had to reprogram in the stations!!! (grin) – JoeFromOzarks Jul 30 '13 at 21:17
Had a go at it with the multimeter. The constant live seems to turn off after about 5 minutes for some reason. Any ideas why that might be? – Dr.Pepper Jul 31 '13 at 22:54
