what is a drive-shaft and why we need it in a car?
I do get the point of having crankshaft (using Wikipedia) but still confuse with drive-shaft
up vote 11 down vote accepted
It's used on front engine rear wheel drive and most 4 wheel drive vehicles it couples the transmission with the rear differential.
enter image description here Picture Source
In the picture above you can see the driveshaft where it's connected to the pinion on the rear end. The drive shaft is the part on the lower right side of the picture. The other end of it would be connected to the transmission.
On front wheel drive cars the driveshaft is not used. The transmission and differential is combined into one unit called a transaxle.
Another view below shows a both the transmission and the rear differential.
The drive shaft, also called a propeller shaft, iscommonly a hollow steel tube with yoke(s) welded onthe end. The tubular design makes the drive shaftstrong and light. Most vehicles use a single, one-piecedrive shaft. However, many trucks have a two-piecedrive shaft. This cuts the length of each shaft to avoiddrive line vibration.
Here is an exploded view of a drive shaft
Pictures and quote source
Here is a car with a rear transmission and the engine up front. They do this for weight balance. The driveshaft is inside the torque tube. That's the tube you see in the middle of the picture.
Driveshaft transfers power from a remotely mounted engine (in the old days, one would say transmission here, but at least one modern car has the transmission all the way back on the drive wheels) to drive wheels. Example, a front engine car with rear wheel drive will have a driveshaft connecting them.
protected by Community May 4 at 20:02
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
