The ignition key for my 2000 Camry has symmetric teeth, and it has always worked when inserted either way. A few months ago the ignition lock started sticking periodically, and I discovered that it sticks when inserted one way, but not the other.
Should I assume that key is worn on one side and replace it, or could there be a problem cropping up inside the lock? If it's a key problem, how would you even cut a new key from a worn one?
