Dealership tells me I need a rear wheel caliper repair. Estimated cost of $500. Is this reasonable? I have Toyota Highlander 2003 model.
up vote 1 down vote accepted
I'm going to assume that they charge a much more expensive price than anyone else would charge for the part. Also, they are most likely much more expensive labor rate than any shop that works on Toyota. So, in terms of a dealership price, it sounds like what I would expect to hear for the job.. The labor on the job is likely to be somewhere around 3.5 hours so if they charge 90 and hour then this would be $315 of that $500 bill that you're looking at.
Also, is it just a caliper replacement? They should be replacing both rear calipers (although it's not a must, it is considered goot practice). they should also be replacing the rear pads and also rotors (if they've been damaged from the caliper failure).
They quoted $200 addition for the pads. Just called around and got a quote from another shop for $395 for both. Wow. Thanks for your help! – Chong Yu Jul 9 '13 at 21:14
Anytime. Best of luck with your truck. – cinelli Jul 10 '13 at 7:05
Every dealership has a "black book" which is a legally enforceable code regarding time spent on labour pertinent to repair.Insist on a fixed price up front and ensure any defunct parts are returned to you.If repairer is not agreeable go elsewhere.It goes without saying;the more competition the cheaper the cost.
