KTM Duke 200 which has an engine of 200 cc, and, on the other hand, Royal Enfield Bullet 350 with a 345 cc engine. I.e. Enfield has 150 cc more than the Duke. But KTM produces 25 BHP of power, whereas Enfield only 19 BHP. How is it so?
Form WikiPedia:
Brake horsepower (bhp) is the measure of an engine’s horsepower before the loss in power caused by the gearbox, alternator, differential, water pump, and other auxiliary components
So it’s not gear box or final drive that makes it more powerful.
up vote 4 down vote accepted
There are two sides to the design and efficiency coin. As a rule of thumb, more modern motors would have better characteristics due to general improvements in manufacturing (machining tolerances are smaller, for instance), and engineering. Liquid-cooled motors are more efficient, as a rule, than air-cooled, and so forth. However, there are also other considerations.
For instance, I have a 250 cc standard motorcycle (Suzuki TU250X). It uses the same basic engine that Suzuki used on its small DR dual-sports, GN standards, and GZ cruisers since early 80s. However, for the new fuel-injected version that Suzuki introduced in the last few years, the newly re-designed top end (cylinder and head) caused it to make less horse-power than earlier carburetted versions (16 v. 20). Why so?
There are multiple factors for such re-design. First of all, the amount of valves were reduced from four to two. Obviously, it would reduce power, because the more, and the bigger the valves, the more air-fuel mixture can be brought in and out. However, the less valves means less maintenance. And for a commuter motorcycle, fuel economy was more important than sheer power.
Design of the valve openings and cam shaft was also rethought to produce more useful power band for this motorcycle. Having high theoretical horsepower does not mean that that power is readily available. Small sport-bikes and sport-like bikes like Duke, CBR250R or Ninja 250 capable of a lot more horsepower (25‒27 in stock form), however that horsepower is available at high RMP (8000‒10 000 or thereabouts), and in regular street riding it is never achieved, unless some one races by overreving the motor on lower gears. TU250X engine is designed to give mild and more even power band, that does not peak as high, but allows more useful power and torque at lower RPM one would use most often in regular urban traffic. As a result, this bike would not win any races and it takes awhile to get up to high speed (though people pushed it past 135 km/h (85 mph) while drafting), but it is a very capable commuter and easily allows over 200 kg of useful load (rider, passenger, and some gear).
Likewise, Bullet 350 affected by two of these factors: it has very old engine that harkens from 1950s, and it is a standard motorcycle workhorse that is designed for commuting, and not racing. Even the brand new RE 500 cc unit-construction engine with EFI is not that powerful for the same reason.
A difference in design and efficiency. More BHP can be made with less torque simply by spinning it up to a higher RPM. Torque has a much greater correlation to engine size than BHP.
Some examples:
6 cylinder, 540cid Lycoming IO-540 makes 300 BHP @ 2700 RPM. It requires something in the area of 600 lb-ft of torque to do so.
My MUCH smaller 4 cylinder, 122cid Mitsubishi 4g63 turbocharged engine makes an estimated 365 bhp (measured 292 whp at the wheels, with an estimated 25% loss with the current transmission), but it does it with just 384 lb-ft (estimated at the crank) of torque due to the higher RPMs the engine runs at (will run up to 8000 RPMs).
Yes, it's a design issue but....
This is the reason.
  • Enfield has push rods and the max RPM is 5200 RPM
  • The KTM has 4 valves per cylinder, good for breathing
  • The Enfield has two valves per cylinder. More valve weight with pushrods = low max RPM.
  • The KTM has an overhead cam. The is makes the valve train very light allows for higher ROM
  • The Enfield has an undersquare piston stroke. The long stoke = a smaller combustion chamber and smaller valves to go along with it.
  • The KTM has an oversquare bore with a very short stroke. This gives the KTM a larger combustion chamber with more room for the 4 valves per cylinder. The short stroke increases your RPM and get's the engine into a more efficient RPM range as well. The short stroke allows for higher RPM operation from the viewpoint of the reciprocating weight associated with the crankshaft.
  • The Enfield is a 50 year old design and incorporates the technolgoy available at the time. Pushrods, rocker arms, long piston stroke, small bore, smaller combustion chamber.
  • The KTM uses the same tech that the RC8 has in the cylinder head. Big combustion chamber, short stroke, giant piston, shim and bucket valve train for RPM operation
The simple answer
The KTM uses modern technology and the Enfield uses technology that was out of date in World War II. Pushrods for the valve actuation!
wrinkles nose as if smelling something rotting
Pushrods are still popular today in the car world (I'm thinking of the LS engines by Chevrolet). Just a different design philosophy. – Zaid Jan 13 at 8:35
