Where are the spark plugs in a 1998 Buick Lesabre? Pictures would be helpful as I'm a novice at this type of thing. I'm assuming I need all six because I'm getting a check engine light saying number 6 is misfiring. Thanks.
Tell me more
Motor Vehicle Maintenance & Repair Stack Exchange is a question and answer site for
mechanics and DIY enthusiast owners of cars, trucks, and motorcycles. It's 100% free, no registration required.
Based on your question here you found the coil pack, follow the spark plug wires to the other end where you will find the plugs. They are in the side of the head where the exhaust manifold comes out. You should be able to see three of them fairly easily from the front of the car. The back are a little more difficult to get to at. You will need to take both of the "dog bone" engine mounts loose so you can rock the engine toward the front of the car to give you enough room to get to the back side of the engine. You can use tie down strap to pull the engine toward the front and hold it there to give you access. Spark plugs are circled below.
The dog bone mount is shown below
