It's a 2000 Camaro v6 manual.
Most days the car starts just fine but on other days I might have to start it 20 times before it stays on.
When I start it, the RPM is around 1000 but slowly drops to around 800 before it dies.
If I apply the gas as the car starts it will die almost instantly.
I just replaced the battery but I'm afraid I stripped the battery terminals.
Today, after trying to start it 15 or so times, I had to pull the keys out the ignition, wait a minute, and start it before it stayed on. I'm not if pulling the keys out the ignition helped.
closed as too broad by Zaid, vini_i, ᴘᴀᴜʟsᴛᴇʀ2, Fred Wilson, DucatiKiller Dec 13 '15 at 18:56
There are either too many possible answers, or good answers would be too long for this format. Please add details to narrow the answer set or to isolate an issue that can be answered in a few paragraphs.If this question can be reworded to fit the rules in the help center, please edit the question.
How's the acceleration? It sounds like you might have a dirty air filter or an obstruction in the air intake. How does the car perform once it's warm? – TMN Jun 7 '13 at 15:28
Sounds a lot like a bad fuel pump or fuel pump relay. – hillsons Jun 7 '13 at 17:35
@TMN, The acceleration seems decent to me. The air filter is clean. If the car makes it more than 10 or 15 feet in reverse then I know it's good. Most times when it has done this I made it 2 feet in reverse before it cut out and gets stuck in this loop. – sparebytes Jun 8 '13 at 1:15
I second @hillsons--this smacks of dying fuel pump. If you're not comfortable addressing that yourself, I'd save money on a tow by making sure to drive it to a shop the very next time it starts! – elrobis Jul 22 '14 at 18:36
......hmm. It's possible it could be the ignition switch, actually, but your observations about the RPMs have me second-guessing now. The 15-20 attempts to start, followed by killing the engine on initial acceleration were identical to trouble I had with my '97 Blazer. Let me ask ..do the dashboard lights come on properly before you crank it, vs. when you crank it and it starts? ....like this: youtu.be/E0iDZUD7M2A – elrobis Jul 22 '14 at 18:41
