Take the 2-minute tour ×
I have a diesel powered Audi A4 B7 (2006) 2.0TDi (the 170BHP variety) with a manual gearbox, which I've owned for around 18 months. The car has just short of 100k miles and has a full dealer service history.
The car was given a service just under 12 months ago, and it was a major service. It's next service is due shortly, but due to the age of the car, I'm considering doing this myself. I'm by no means an expert, but have done numerous DIY jobs on cars over the past 20 years.
The car isn't reporting any problems (and my OBD2 scanner reports no faults logged on the ECU)
The car is starting to become difficult to start when the engine is cold. My first thought was that it could be the glow plugs, however after some reading, I believe that glow plugs are only required when temperatures are approaching freezing, which isn't the case here in the UK at the moment. This morning, the ambient temperature was in excess of 10 degrees Celsius, and the car took around 5 seconds of starter motor activity before the engine fired up. Once the engine was running for a few seconds, the engine ran as normal.
Later in the afternoon, when leaving work (the car had been stood for over 8 hours), the ambient temperature was around 20 degrees Celsius, and the car took several minutes to fire up, with around 5 attempts with the starter motor for between 5 and 10 seconds per attempt. Again, once the engine fired up, it ran as normal. Given that the engine/ambient temperature was higher in the afternoon and it took longer to start, I'm increasingly thinking it isn't glow plugs.
The normal engine running condition is fine, but whilst the engine is cold, it does smoke quite badly (not enough to fail an emissions test), and the idle speed can be erratic when cold. I reported this to our Audi dealer when they serviced the car last year, and they assured me that there was nothing wrong with the car (I didn't buy the car from the dealer, so they have no reason to lie).
There is a known problem with the injectors on this engine model, but my Audi dealer was able to check back on their computer and confirmed that all the injectors had been replaced under a recall due to the fault (by a previous owner). I asked them to double check, and they told me they checked one of the injectors, and it was indeed an updated one that didn't have the known fault. - again why would they lie, they'd be losing a sale.
The car is used daily and probably does around 1,000 miles a month, and despite my concerns about the erratic idle speed and smoking when cold, it's been very reliable until this recent problem starting with a cold engine.
Could the car simply need a service (oil change, oil filter change, new air filter, new diesel filter, etc) or could there be a more sinister problem looming?
Update
This morning the car started perfectly first time. Last night I filled the car up with Diesel, and the car did around 20-30 miles before being parked up for the night. Could this be related in any way?
It's been suggested to me that the EGR might be clogged up, so I'm purchasing a diesel fuel additive designed to clean the EGR, valves and injectors. Fingers crossed, this will solve the problem. –  Bryan Aug 31 '14 at 13:13
Any new updatrs on this? Did you fix the problem? I have the very same problem. Thanks –  user7441 Nov 6 '14 at 14:28
@MarkoGrohar Nope, still suffering. I've used diesel fuel additives that are supposed to clean the fuel system, and Wynns stop smoke oil additive at the last service (about 3 weeks ago), but still having the exact same problem. Once the car is up to temperature, it runs perfectly. I'm currently suspecting worn valve stems, but that's just a hunch/guess, as I'm a computer programmer, not a mechanic :) –  Bryan Nov 7 '14 at 17:39
I never did get to the bottom of this problem and I've since traded in the car. I guess I'll leave the question open should somebody manage to find a solution. The problem seemed to be worse when the engine temperature was transitioning from cold to hot (but not when cold or hot). –  Bryan Feb 4 at 0:06
4 Answers 4
Couple things you might want to check.
Coolant temperature sensor. With a cold engine the ecu should try to dump more fuel in for starting. If the sensor isn't working it might send the wrong amount of fuel and inhibit starting.
Idle Air Control valve. This going bad could cause similar issues.
+1; Thanks Mike, I've been reading up on this, but need to research it a little more. I'm going to start by checking the ohms readings for the coolant temperature sensor and see what I find, although the readings on the dash for this look normal. –  Bryan Jun 8 '13 at 11:18
There are three relays located under the ECU, within what should be a water tight ECU housing. Apparently this is a common fault, and the relay contacts will often corrode.
One of the relays is for the glow plugs, another relay is for the radiator cooling fan.
So it's quite likely that this is the problem.
if you engine strugle when is cold and start fine when hot and the car run fine after with no lost of power I will check this few thing like =
First check you baterry 12.7 v or above good battery under 12.3 V get a new one .
then is very likely your starter motor not turning quick enough . if you car is 10 year old plus I will recomend to check you starter motor.
this are the main two raison why your car is not starting from cold
after you can check your injector but if the car run fine I would be surprise if this is your problem
the other one cause which I hope you never have is the HP fuel pomp not working propely while crancking the engine with the starter motor this mean expenise repair as the hp fuel pomp usualy work with the timing belt and the part hp pump is expensive new , I would recomend a second hand if you have a old car as they are usualy good this day but they go wrong like everything else . I hope this help .
I had a similar problem with my navara bakkie - appears it was the fuel filter allowing air into the system. Replaced this and changed the clamps on the fuel lines where they join the fuel filter. Seems to have worked.
