I had to have a tire repaired today on a new 2013 Honda Accord. When the tire was repaired for a puncture, I saw nothing that looked to me like a tire pressure monitoring system inside the wheel or on the valve stem. It is as if this particular wheel did not get the pressure system installed, or it is so small I can't even tell it is built into the valve stem. What makes these work?
vid showing the stem with the tire removed: http://sdrv.ms/Zs3UlQ
up vote 5 down vote accepted
There are two basic types of systems, direct and indirect. You have an indirect system.
Direct systems use a pressure sensor and transmitter for each wheel. They send pressure information from each wheel to a computer module on the car. Some of these systems provide real time pressure and temperature readings to the driver.
Here is an example of one of the sensors enter image description here
Source
Indirect Systems look at the wheel speed of each wheel (Using the ABS wheel speed sensors) and compares its speed to the others. If a tire is under-inflated it will spin faster because the tire is smaller. These systems don't know which tire is flat, just that a tire is flat, or maybe not flat just less than the other tires. There are some advance versions of this system that use signal processing to detect all of the tires being under inflated. Since they would all rotate at the same speed if they all had the same amount of under-inflation.
@JoshCaswell Updated my answer with a little more info – Move more comments link to top Jun 5 '13 at 20:06
Thanks for the update. Mine was definitely the indirect system as you said. What is monitored, the differential or each individual tire speed? – Roger Jun 12 '13 at 18:25
The ABS system detects the difference in rotational speed as the tyre deflates and spins faster.
Bradley
