My car (2005 Nissan Sentra) had a problem for a while: gas spills out when pumping. I was lazy and did nothing about it. After a month or so, the car started to fail. At first it was only hiccups, but now the car won't go faster then 5 m/hr and pressing the gas pedal has almost no effect.
I found a forum that said that the Sentra had a known problem with the vent control valve and that it was easy to repair. I removed the part and it was indeed broken. I replaced it, but pressing the gas pedal still has no effect.
Is it possible that the car is in "fail safe" mode and that restarting the ECU could resolve the problem? If so, is it possible to reset the ECU without a scanner?
Try pulling the battery cables off for 30 minutes and report back. – Mike Saull May 23 '13 at 15:32
@MikeSaull Thanks! I will try it and let you know the result. – W3Max May 23 '13 at 15:40
Oh take the negative off first. When putting the cables back on put the negative on last. – Mike Saull May 23 '13 at 15:52
(NOTE: Since @MikeSaull didn't put his answer down, I'll answer for him)
Try pulling the battery cables off for 30 minutes. This will reset the computer back to factory specs and hopefully will solve your issue. Pull the negative battery post off and not the positive, as this can have adverse effects.
