Take the 2-minute tour ×
I have a Hyundai Elantra 2002 and changed its power steering fluid with a turkey baster. Four days after changing the power steering fluid and running 1000 miles I noticed that the power steering fluid is leaking. I filled it up up to Max level when I changed it, but after four days it is leveled at Min. So apparently, it is leaking. It was not leaking previously, but now after changing the power steering fluid, it is leaking. Is it normal? What should I do?
What was the level before you changed it? What's the source of the loss (have you found any leaks)? As a side note, I've found that in my Eclipse there's no point in filling it over about halfway between min/max as it will just blow any more than that out. –  Brian Knoblauch May 23 '13 at 11:45
it was between min and max before change. The reservoir and the hoses connected to it are fine. But I see some drops by the wheel near passenger side. I cannot say for sure what the source is. Update: I checked the level today in the morning, and it is now below min. So, it is definitely leaking even when the car is not running. –  aminfar May 23 '13 at 13:11
You can always try adding power steering leak-stop fluid to the system and see if that makes the problem go away. :-) –  R.. May 26 '13 at 2:41
yeah, I am doing it, every two or three days. Still no luck, let's see. –  aminfar May 27 '13 at 21:58
up vote 2 down vote accepted
There use to be a say that you never changed you transmission fluid from whatever to whatever, due to detergents eating up any little bit of soil that might have been holding a leak back. Assuming you used the same fluid type, and the other fluid was filthy enough to have a positive viscosity gain, the new fluid might have found the weakest link. Look for the hose with dirt on it, and trace it. Also, look at you steering rack, as this might be the source of the leak. If available, top the fluid off, and have someone turn the wheel from maximum left turn to max right. Observe all the components, and look for your culprit. Another thing to do is check your hoses for a breach, and if you find one, you might as well replace all hoses to avoid the weakest link failing next.
