I have a Hyundai Elantra 2002 with 84K miles and would like to change the power steering fluid using a turkey baster. (1) I was wondering how much power steering fluid I need for my car? the user manual does not say anything about it. (2) The manual says I need the PSF-3 type for my car. PSF-3 is not found any where. So, I went to O'Reily Auto parts and bought the power steering fluid made by O'Reily. Is it good enough?
I did a few days past, and I used 2 quarts. – aminfar May 21 '13 at 15:23
Is that all the manual says? I believe you can use Dexron ATF, which is reddish in color. I would verify though, as PSF-3 is no longer made.
Aminfar,
I have a 2002 Hyundai Elantra GLS with 75k miles, which I actually just purchased recently. I am not a mechanic, but when I called about replacing power steering in my Hyundai I was suggested Prestone Power Steering Fluid (which I picked up at my local Autozone). My mechanic friend told me Prestone is the next best thing since they don't make PSF-3 anymore. Got it for around $7.00, and I topped it off and I'm not hearing any problems. Just took a trip for 600 miles and it was smooth sailing. Planning to flush it out since it's past due for an actual flush. Hope this helps.
You cannot properly change your Power Steering fluid with a Turkey baster! Your Power Steering System contains much more fluid than what is in the Reservoir. I usually remove a hose on the return side of the pump and allow it to pump itself dry( a few turns of the Steering wheel will do that) then refill the system whilst having an assistant move the steering wheel lock to lock as is possible. I would have no idea as to the amount of fluid you would need as every system is different but I would have at least a quart to 1.5 quarts(2 liters)on hand. You can never have too much but too little may spell danger(so to speak).
