I have a Hyundai Elantra 2002 with 84K miles. The transmission fluid is pretty dirty and it seems like it needs some attention. I did a little of bit search online and found out some people suggest that transmission fluid for old cars should not be flushed. They say it should only be changed because tranmission fluid flushing for old cars might release deposits and cause some damages later. So I don't know what it right? flushing or just changing?
PS: I bought this car a couple of years ago when it had 73K miles. I got half of the transmission fluid changed at 77K (maybe even less than half, don't remember). I don't know if previous owners ever changed or flushed the transmission fluid.
possible duplicate of Should you change all of your transmission fluid? – Nick May 15 '13 at 0:34
I have seen that post, but not sure it is directly related. If you flush your transmission fluid regularly (lets say every 30K miles), then flushing is a good thing. But considering old cars like mine that I have no past record, I don't know what the right thing is. – aminfar May 15 '13 at 1:50
If you already flushed roughly half, I'd think your chances are good that nothing terrible will happen flushing the rest. – Nick May 15 '13 at 14:04
up vote 1 down vote accepted
The transmission flush usually involves some kind of a cleaner going into the transmission to dissolve varnish and to dislodge the buildup of particles. As the transmission works, the gears touch one another and wear small particles away and those collect in the crevices and nooks in the housing and pan.
Whereas if you were to get a fluid change, this means the old fluid is removed and new fluid is replaced.
There can be two different types of fluid changes: One is where the bottom of the transmission is opened, the fluid is drained out, and the filter is replaced. The second type is when a machine is connected to the "cooler lines" (explained in more detail below) and All the old fluid is exchanged for the new fluid.
Some transmissions may have a small radiator that is located near the engine coolant radiator. The fluid from the transmission circulates through lines and goes from the transmission to the radiator and then back to the transmission; it helps to cool the fluid.
When the bottom of the transmission is opened and drained, there is still a lot of fluid in the inner passages and torque converter of the transmission- so not all of the fluid is changed out.
When a flush is performed, the old fluid is removed from the "cooler lines" and the new fluid is added through them, so all of the old fluid is taken out.
Bottom Line: I wouldn't flush the car due the seals breaking, other things going wrong, etc that would end up costing you more money. BUT ALSO: Like Nick said, if you've already flushed half of it, might as well flush the rest since you're halfway there :P
