I'm relatively new to motorcycles, my flat mate taught me how to drive his two Royal Enfields around New Delhi, and for the past year and a half I've been taking care of them as they break down ;)
Was just curious what the 'cc' actually means when you say a Hero Honda has 150 cc, or an Enfield as 350 cc, or a really beast Enfield has 500 cc. I know vaguely that more cc is more powerful, but am curious as to how one could actually measure cc.
What happens when they rebore it.. It will change cc too..? – user3732 Sep 21 '13 at 14:57
up vote 30 down vote accepted
cc is the size of the engine, in cubic centimeters - literally the volume of the cylinders. A larger cylinder can ingest more air (and more fuel), thus converting more energy per cycle than a smaller one, so making more power - assuming all other factors are the same, and there are many factors that affect power output.
You can measure it by a simple volume calculation - area of the piston (pi x radius squared) x stroke x number of cylinders.
Its worth noting that the size the bike is marketed as is rarely exact for example my Ducati Monster M600 (600cc) is actually a 583cc engine. – Mauro May 14 '13 at 14:24
Indeed - the same is usually true of car engines - my 1.6L Honda is actually 1595cc – Nick C May 15 '13 at 9:00
one of the reasons for the above was to also circumvent cc based taxation slabs. – chilljeet Feb 27 '15 at 10:28
Don't forget that to calculate the total cubic capacity of an engine you may need to take into account nuances in the engine design. Some pistons have a dished crown and some allowance may be needed for the "squish band" machined into the face of the cylinder head but generally pi x bore diameter x stoke x number of cylinders will get you somewhere near. – Steve Matthews Aug 3 '15 at 10:06
A cubic centimetre equals one ml (millilitre), or one thousands of a litre. In other words 1000 cc equals 1 litre. – Pepijn Schmitz Aug 3 '15 at 14:51
The "swept volume" of one cylinder is given by :
pi * r^2 * L
r = cylinder radius (bore / 2 ) in centimetres L = stroke in centimetres
Then multiply by the number of cylinders (they will all be the same bore and stroke)
Example : Bullet 350 bore and stroke given as 70 mm ( 7.0 cm) bore and 90 mm (9.0 cm) stroke So : r = (7.0 / 2) 3.5 cm L = 9.0 cm Then : pi * 3.5 ^2 * 9.0 * 1 (cylinder) = 346.3606 cubic centimetres Note : the capacity is usually rounded, in this case to 350 cc
"cc" Stands for Cylinder Capacity or Cubic Centimeters. Luckily Cylinder Capacity is measured in Cubic Centimeters, so it's all good. As others have pointed out, bigger cylinders make more power because they can burn more fuel per stroke.
the actual meaning of cc is the cylinder capacity so larger the cylinder more area avalible for burning of fuel so the larger the space for the moment of piston is also provided in this case so more power will be generated when cc is larger
Um, cc means cubic centimeter not cylinder capacity ... 500cc is 1/2 a liter. – Pᴀᴜʟsᴛᴇʀ2 May 28 '15 at 22:39
cc is nothing but the total displacement volume of a piston inside the cylinder. as cc increases, there will be more intake of air fuel mixture and output power ofthe engine will increase...
you are not correct. – DucatiKiller Jun 1 at 21:38
