97 pontiac grand am se v6, a while ago my car did not start, I guess it was the ignition switch. So it got repaired but then the other day it wouldn't start. And it would not shift out of park at all, but when I went to take it to the same shop everything worked but I took it in anyway. When I got it back it ran fine for a day, then my radio, wippers, defroster and dome lights would not work so I checked the fuses and replaced one and it started and everything works even without the key. Now its having trouble starting it starts in about 1 in 30 trys. Can anybody help me?
Tell me more
Motor Vehicle Maintenance & Repair Stack Exchange is a question and answer site for
mechanics and DIY enthusiast owners of cars, trucks, and motorcycles. It's 100% free, no registration required.
Sounds like a charging system problem or a parasitic drain on the battery. Check the parasitic drain by following this video. If none found you may need a new alternator/battery. |
I would start looking at the steering column wiring. I think you have a pinched,cut, chafed etc wire. The fact that you blew a fuse and the accessories work without the key leads me to believe you have power being applied when it shouldn't be and not being applied when it should be. Be careful about random probing in the column as you can inadvertantly discharge the airbag. |
