Tell me more ×
  1. Why are copper washers required on banjo fittings?
  2. Why do they need to be replaced each time you remove/loosen the banjo fitting?
I'm assuming that copper is a softer metal than bronze, brass or steel so they will squish when torqued to make a seal. However, I've seen copper crush washers that had an embossed ring in the center of the washer that would actually crush down when under pressure. Today I had to replace the washers for an oil feed line for a turbo but the manual calls for copper washers and not crush washers. Do the flat copper washers work in the same way?
1 Answer
up vote 5 down vote accepted
You are correct that the copper washer is required to create a seal.
Even flat copper washers will deform during tightening to create a seal. They're made from annealed copper, which is very soft. The raised ridge just reduces the load required to initiate the seal.
Generally, these washers should be replaced rather than re-used, as the act of deforming an annealed copper washer effectively "hardens" the material, making it more difficult to crush next time, therefore you may not get a good seal when re-using a copper washer.
The is a great answer. Regardless of the the topic of the question. It's straight to the point, contains facts, no bs. +1 – cinelli Mar 26 at 19:19
