This question already has an answer here:
In a Automatic Transmission vehicle, changing gear to Neutral at all possible times like,
  • before breaking for stopping for a color light
  • or driving downhill
will save the fuel in a considerable amount? or is it a bad practice?
marked as duplicate by jmort253, Rory Alsop, Nick C, Nick, theUg Mar 6 '13 at 16:17
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
Hi Nalaka, if the answers posted on the duplicate don't answer your question, please strongly consider an edit to your post to add in details necessary to clarify what you don't understand. Good luck! :) – jmort253 Mar 5 '13 at 3:42
The edits have actually made this question more of a duplicate rather than less. Is there something unique that you'd like to cover not previously addressed in other questions? – Bob Cross Mar 5 '13 at 16:06
up vote 2 down vote accepted
Coasting in neutral does not do you much good in fuel-injected car, because under the engine braking modern control units shut off fuel completely, whereas when coasting, engine is still running on idle. As for stopping at traffic lights, I usually switch to neutral to reduce wear of the clutch, and load on the engine. Better yet, if the stop is going to be reasonably long, I shut off engine completely, as restarting of a warm engine does not take much, while excessive idling is bad in general, and bad for fuel economy in more ways than one.
Most wehicle owners manuals advise against towing the vehicle with drive wwheels on the ground if it is equipped with an automatic trans. The reason for this is that wheels will turn the transmission internals. The parts will not be lubricated due to fluid flow in nuetral vs in drive. This may cause accelerated wear. Rolling in neutral is causing the same condition. As others have stated in similar questions sitting in neutral may have little advantage in terms of fuel savings however it does no harm.
Note that it applies to long tows (sometimes they specify it as 20, 30 or 50 miles). Under the regular driving conditions this is not applicable, unless you live near fifty-mile shallow grade descent. In that case, I would put coasting down there on my bucket list. – theUg Mar 6 '13 at 16:20
