Tell me more ×
I have a 1998 Acura Integra with 204k miles on it. Some mornings after the car has been parked in my driveway facing up a slight slope overnight with the handbrake set, the first time I apply the brakes while backing out causes this very loud metal on metal noise that reverberates through the car. The brakes are fine thereafter and don't stick or make noise when braking while moving forward. The simple solution is to back into the driveway, but I'd like to know what's going on. Any clues?
up vote 2 down vote accepted
How humid is it outside when this happens? It could just be surface rust getting scraped away. This usually isn't very loud, but kind of a low metal on metal slushing/grinding sound.
It may also be that your brakes are "resonating", which is a term I just invented to describe the somewhat loud, low reverberations that are caused by the brakes quickly grabbing and breaking free of the rotor at a high frequency, 60-150 Hz or so (is my guess). I am able to do this in a lot of automatic cars (at any time during my trip, however) by pressing the brake only slightly, holding it at just the right spot. This allows the car to move forward at 1/2 MPH or so and it has this effect.
That's true too, on cold foggy mornings my brakes can be a little cranky when I pull out of the driveway, but usually you have to listen to notice, it's not very obvious. – hillsons Mar 3 at 22:53
Well, we have two theories now and it's wet and the car will sit overnight. I'll check for rust and worn pads tomorrow. Thanks! – nwellcome Mar 4 at 1:59
Honda's and Accuras are famous for using wear indicators that are shaped/oriented a specific way that causes them to grind only when you reverse. In all likelihood you have a worn brake pad and probably some rotors that need to be replaced at the same time.
