Take the 2-minute tour ×
I am a complete newbie when it comes to jeeps (and cars in general). However, I am very good at fixing things... once I know what the problem is.
After a summer of riding with the top down I was used to the loud noise of the air going by, but once I put the top up at the beginning of winter I instantly noticed a rubbing noise coming from my drive train. I can only hear it when I am driving with the clutch engaged and the faster I am going the louder it is (so I know it's behind the transmission). I didn't think much of it because I only had the jeep for a month or so with the top up before I took it down for the summer. Now I have been driving it with the top up for a couple months and the rubbing noise has gotten louder.
I don't really like taking my car to the dealership because in the past they have completely made up problems that didn't exist - so I would love to figure this out at home. All help is appreciated.
Some info about my jeep -- It's an 04 Wrangler X. I bought it used spring of 2012 with 22k miles on it. Everything related to the drivetrain is factory installed. I make sure to check the fluids regularly and they don't seem to be an issue.
add comment
So you need to find out where on your drive train. Get your Jeep up off the ground so you can drive the wheels, and have a listen.
Likely places:
  • Differential
  • Universal joints on axles
  • Tire rubbing on bodywork
  • Brake pad rubbing against disc
Hmm. Can't be the tire rubbing or the brakes because it's only when the clutch is engaged. The noise is most noticeable when I am in a high gear (3 or 4 or 5). I'm not that comfortable running my jeep in my garage in 5th gear - where should I do something like that? And if it were the diff wouldn't it only make a rubbing noise while turning? –  Keegan McCarthy Feb 15 '13 at 19:06
If you don't have the necessary lift or stands in your garage I'd probably suggest taking it along to a local mechanic. This will also have the advantage that they can listen as well, and will be in a very good position to identify the noise. –  Rory Alsop Feb 15 '13 at 20:24
That's a good idea. I think that's what I have to do. –  Keegan McCarthy Feb 15 '13 at 21:47
add comment
