How do I change the rear lights on Peugeot 307 CC?
The CC (Coupe) version doesn't seem to have a visible place to open the back light cover.
Factory repair manual is a bit sketchy about it, but here what it says (translated from Russian version):
  • Put the roof in the intermediate position (I suppose, somewhere in the middle between fully open and fully closed).
  • Cut out (?) and remove the carpet (1 on the figure). That cutting out bit puzzles me. Maybe, just pull out from under the trim?
  • Partially pull out inner lining (2).
  • Release the fasteners for the rear light, pull it out, disconnect the harness, then remove it.
The picture and instructions are rather confusing for someone who had not seen the car in person, but hope this helps. If it does, please, comment here and clarify, so I can edit the post for the next person with the same problem.
These instructions are for the fender part, let me know if you need those for the trunk lid as well. – theUg Feb 17 '13 at 17:32
open roof till bonnet sits back,then go no further,at rear on top, small plastic panel pull it off,you will see nylon thumb screw nut,undo pull light fitting out,reverse process to put back together
