Tell me more ×
I have a 89 Mercedes and a few days ago the wiper blades stopped working as well as the windows. They were iced over and I cleaned off the ice and tried again the next day. There is no sound when turning things on. I also tried the windshield washer fluid and nothing happened.
It's still very cold and I think the arm may be up a few inches rather than in its start position but I would have to check again.
Clarification: were the blades iced over when you tried to cycle them? As in, the motor tried to move them and couldn't due to the ice? If so, possible blown fuse. – Bob Cross Feb 6 at 16:50
at one point I could hear the motor working. it was the next day (didnt end up driving that day) when i cleaned off the ice and tried again that I didn't hear the motor. I'll check the fuses tonight. – 1.21 gigawatts Feb 6 at 19:11
Good luck - if that turns out to be the problem, please answer your own question below. There's a 100% chance that someone out there in the internet will have exactly the same problem and will appreciate the pointer from a fellow sufferer. – Bob Cross Feb 7 at 13:00
You are my hero. That was it. It works now. – 1.21 gigawatts Feb 7 at 17:26
1 Answer
As Bob mentioned in the comments the problem was the fuse was blown. I replaced the fuse and everything is working again. On a side note, another fuse was blown and after replacing that the sunroof is working again.
BTW For future reference the fuses are special fuses (not sure if they are special or not) in that I had to get them at an auto store. You can look online, for example Amazon, and give it your make and model and it will describe the type of fuses you need.
Well done - extra kudos if you take a picture and / or provide a part number for the person searching for the exact same thing in the future.... – Bob Cross Feb 7 at 20:37
