This morning I got in my car (Mk3 Golf) and went to start it. The engine will turn over indefinitely but not start.
On my second attempt, again it would turn over, but as soon as I let go of the key it would stop and let out a big puff of smoke. The smoke (from what I can tell) is coming roughly from the area near the cam belt cover and the top of the block (not sure what else to be looking for around here and terminology. I want to say carburettor?)
I've checked the HT leads and distributor and they look fine. I've also been told it could be the coil. I'm a bit lost though at this point and any suggestions would be much appreciated!
This is Mk3 Golf SE 1.8 – Miles Hayler Jan 31 '13 at 9:22
European spec Golf? Did you check the spark? – theUg Feb 1 '13 at 4:31
No, will check the spark tonight. Further to this, the car started a few days ago perfectly, but is now acting the same. Going to replace the plugs, HT leads, distributor cap, rotor arm tomorrow. If that doesn't sort it I'll do the coil. – Miles Hayler Feb 4 '13 at 8:56
Tried: change plugs, HTs, distributor cap, rotor arm. Tried: jumping, starting with air box open. Spark plugs are sparking. engine lets out a splutter as soon as you stop turning it over. had a puff of smoke out the air box too on opening it. it's almost like the fuel isn't reaching the cylinders and is burning in the single point injection system. – Miles Hayler Feb 11 '13 at 15:28
So, I take it you still having issues? It started after tune-up kit, but then went back to old ways again? – theUg Feb 11 '13 at 16:03
up vote 1 down vote accepted
I had similar issues with American-spec 2.0 ABA motor. Now that you had clarified that it still occasionally starts, broken timing belt is not the issue. The proper tune-up, however, might be in order.
The problem I had was due to the fact that my spark plug wires were worn, and reacted poorly to damp environment. More likely, because of deteriorated insulation with micro-cracks through which moisture could come in contact with the leads and cause shorting. I would have trouble starting in wet weather, and after a car wash it would not start for an hour at its worst.
While the new wires could be all that is needed, full tune-up kit, including distributor cap and rotor, should not be very expensive, and it is a good idea to replace those parts. I would not, however buy the new coil until you see if the tune-up kit rectifies the problem, or, otherwise, I would still check if it operates properly before you start replacing half of your engine compartment. Check the battery as well, while you’re at it.
Cheers, I'm planning on changing (initially) plugs, distributor cap and rotor arm. If that doesn't work, I'll look at HT leads, and finally the coil. – Miles Hayler Feb 4 '13 at 10:33
The distributor cap was a state. Changed the parts and it started first time. Thanks for the help! – Miles Hayler Feb 5 '13 at 9:09
To start a petrol engine you need three basic things - compression, fuel and spark. If it won't start, you're probably missing one or more of these.
Does it sound normal when you turn it over, or does it spin excessively slow or fast?
Immediately after trying to start it, smell the area around the exhaust. Can you smell unburnt fuel?
The big puff of smoke from the top of the engine sounds concerning. It sounds like it's coming from the inlet side around the injector area? Does it look like oily smoke (black or blue), steam (white) or fuel vapour? Smell might also help here, but be caseful in case it is hot!
What does the oil look like? Pull the dipstick, and check for a thick fluid of mayonnaise-like appearance. Does it look like there is oil in the coolant?
HT systems have a habit of failing whil still looking fine. To test that, remove one of the plug leads, and attach it to a spare spark plug. Lay the plug on the top of the engine, so that the threaded bit of the plug is in contact with an unpainted bit of engine. Try to start it, and watch the plug to see if there is a strong spark.
It turns over at normal speed and there is a smell of unburnt fuel. – Miles Hayler Jan 31 '13 at 16:28
The puff of smoke is black and looks to be coming from around the inlet side, around the injector area (from what I can make out). I will take a look at the oil and see if I have a spare spark plug when I get in from work. – Miles Hayler Jan 31 '13 at 16:31
