I recently replaced my muffler, and attached it to the existing pipe using clamps around a short coupler pipe (sorry, I don't know the right name for these things) that fits around the outside the the pipe attached to the muffler and the existing pipe under the vehicle. I wasn't able to get a straight (same diameter all the way) coupler around the existing pipe, so I chose one that was slightly larger at the end that goes around the exhaust pipe, and rather than fitting perfectly snug, the coupler buckled and exposed a gap (and exhaust leak) when I tightened the clamp down on it.
I'm pretty sure to fix it properly I'm going to have to rip the coupler pipe back off (probably with my Dremel) and replace it with something different, but I'm not sure how to determine the right parts I should be using? Do I just need to sand down the (moderately rusted on the outside, but still intact) exhaust pipe under the car and try to get the smaller coupler pipe around it? Any good resource for beginners doing exhaust repair work like this?
I can take some pics or pipe measurements if it would help.
What are the relative dimensions of the pipes? Presumably one or both are aftermarket components if they don't fit together properly. How did the old bit come off - was it a sleeve fit, and did you have to cut it off? – Nick C Jan 28 '13 at 16:12
The pipe is aftermarket; it was replaced before I owned the car. I had to cut the old coupling off with a dremel so I didn't get a good measurement of it. I just went by what seemed to fit while picking through parts at the auto parts store. – R.. Jan 28 '13 at 16:38
The auto parts store can probably rent you a pipe expander. Once you get the pipes apart you can use the pipe expander to change the diameter of the pipes.
Be sure not to rip one from expanding it too much!
