Tell me more ×
I'm trying to remove the transmission casing on my belt drive scooter. All of the bolts have tiny 8mm heads, and are very cheap and soft - cheap Chinese manufacture - and one was already slightly rounded, from assembly as a new bike.
I have now sprayed Q10 penetrating oil, and waited a few minutes before tapping lightly with a hammer, on the front and sides of the bolt head. What is really worrying is that when I tap the side of the bolt head, it moves as much as 0.7mm, in any direction. The head is too close to a casing piece to get any good grip with a vice grip.
What can I do here? There is no room to cut a groove with a hacksaw, but maybe if I get a thin enough grinding disk on an angle grinder I can cut a groove, or maybe grind the head flat enough for a vice grip to hold.
What can I do?
A picture might help us make a more specific recommendation. – Bob Cross Jan 19 at 15:56
Do you have a Dremel that you could slot it with? (Or a friend with a Dremel?) – Doresoom Jan 19 at 21:46
I found a miniscule angle to get a hacksaw in and cut a slot in the bolt head. Then I hammered a screwdriver into that and shocked it left and right with locking pliers. – ProfK Jan 20 at 6:13
1 Answer
You can try heating it with a torch to loosen it. You could also get a reverse-direction drill bit, and drill down into the bolt; the heat will help the reverse bit to unscrew it, and if not then you can easily get the remainder of the bolt out by stepping up bit sizes.
The reverse direction drill bit might be perfect for this application. – Bob Cross Mar 4 at 22:13
