All 3 brake lights on my Prelude seem to be permanently stuck on. This occurs all of the time - the lights stay on even if there is no key in the ignition. I've had to disconnect the battery.
Would anyone know of a way to fix this? Thanks!
All 3 brake lights on my Prelude seem to be permanently stuck on. This occurs all of the time - the lights stay on even if there is no key in the ignition. I've had to disconnect the battery. Would anyone know of a way to fix this? Thanks! |
Follow the brake pedal arm up under the dash. This may require some plastic trim to be removed. Looking up you should find a switch that is activated by the brake pedal arm. This switch may have failed or fallen out of the mount. |
