Is there any way to adjust the vertical alignment of the headlights on my Milan? The driver's side headlight shines up too high. Also, there is a dark spot in the middle of the beam. Could these two problems be related?
Tell me more
Motor Vehicle Maintenance & Repair Stack Exchange is a question and answer site for
mechanics and DIY enthusiast owners of cars, trucks, and motorcycles. It's 100% free, no registration required.
The adjustment screws should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support. Once you have adjusted the bulb, see if the dark area goes away. It could be connected with the alignment. |
