So I bought new tires recently for my 2002 Nissan Sentra and wanted to make sure that my alignment would not eat them up. Even though effectively my entire suspension/axle system was overhauled recently, some of the specs are still off. Three different shops keep telling me that it's not a huge deal and won't make my tires wear improperly.
This is the report from the last place I went to, other reports show a similar story, though this one shows probably the most "extreme" deviations (though I have a feeling these sensors aren't very accurate)
Should I be worried? I am not sure why the front caster is out by a tad bit, seeing as that is a brand new shock there. The rear though, is not adjustable, it is a solid axle and the print outs all say "Manufacturer does not specify rear Toe/Camber adjustments". I've already had this axle placed with a new Nissan Part.
