A few weeks ago, my Rebel 250 blew a piston, allowing the piston rod to beat on the top of the cylinder and the valves.
There's some scarring there now, as well as a jagged protrusion or two. What are my options for repairing this scarring?
Can I hone it down to simply get rid of the jagged bits, then brush it out?
Or should I replace the entire cylinder head?
Here's an image of what I'm working with. It's not great, but the damaged head is on the top.
Image of the damaged cylinder; on top
up vote 4 down vote accepted
Depending on the depth of the scar, honing might work. Otherwise, depending on availability of parts, you can replace the cylinder head.
Thanks for the response! I posted an image of the damaged cylinder head, if it helps any. – BrMcMullin Nov 30 '12 at 21:36
If the damage is mostly superficial, and it's not warped or causing a gasket leak or a valve leak ( which could let coolant into your oil and then you will have problems), I think that you could very easily get by without replacing the cylinder head.
