Tell me more ×
We recently purchased a 2007 GMC Sierra and are looking for some details on the assembly for the spare tire. The truck did not come with the rod assembly for the spare tire and we were hoping to make some ourselves, but need some help determining the size of the male adapter at the end of the rod picture below. enter image description here
We've tried 3/8 extension but it just spins inside the spare tire hoist.
My guess is a used unit from a salvage/wrecking yard would be a lot less work – mikes Nov 24 '12 at 21:28
@mikes they are expensive and hard to find, at least in my area. All the dealers buy them for their used cars, and keep the demand high. The last time I asked for the jack setup for a truck of mine it was $100, I chose to do the same thing as the OP because of it. – Larry Nov 25 '12 at 16:07
1 Answer
up vote 0 down vote accepted
I don't know the size you need. It's a hex most of the time, I thought about welding several nuts of the correct size together on the end of tubular steel. That may be the route you need to take.
I had the same problem on a 1999 Yukon so it should be similar to yours
I was able to use a piece of 1/2 inch square tubular steel by itself. It wasn't an exact fit but worked without any modification. I just use a wrench to turn the rod instead of making a t-handle because it was easier to store.
