Tell me more ×
I have a 1999 Dodge Dakota. Early in the spring I had to have my heater core replaced. Now it is starting to get cold outside. When I run my heater it is getting luke warm at best. Before the heater core was replaced it used to be a lot hotter. What could have caused it to not kick out very much heat?
I regularly check my fluids and the coolant level is always right where it should be.
up vote 2 down vote accepted
You very likely have a bad thermostat. Here are some similar questions that may provide some insight:
Where'd my heat go?
Why would my heater sometimes blow cold air?
Engine never warms up (actually: it cools down) at highway speeds
In terms of your specific problem, I would check your engine temperature gauge: does the needle ever move up to its normal operating range? Or does the coolant stay cold?
Thanks for the answer, I am sure I will fall into one of those categories. – Linger Nov 21 '12 at 15:18
I would remove the heater hoses and flush out the heater core using a garden hose. Be sure to flush it both ways. Test for leaks when done and add coolant as needed.
