Tell me more ×
Summary
How do you get to the battery on a 2012 Honda Odyssey, given that it is blocked by some type of intake tube**?
**Edit: this used to say exhaust but I changed it to intake tube, given the answers, below.
Details
We have a new 2012 Honda Odyssey and our old car battery just died. So I'm trying to give it a jump but the Odyssey's battery is blocked by something that I can't remove.
Does anyone know how to remove these fastener/screw things (at the bottom of the picture below)? I've tried turning them as well as prying them with a butter knife. The red terminal is accessible but the black one is completely blocked by this thing. I need to get to both to jump my car.
Battery blocked by something I cannot get off
You can also attach the ground (negative) to the engine block for jump starting. – Tim Nov 12 '12 at 14:21
I'm pretty sure that, unless there's something special about Honda Odysseys, it doesn't require both battery terminals actually. When I say I'm "pretty sure" I mean I have done this multiple times with my BMW, where the battery is in the boot. – Sam Jones Nov 12 '12 at 16:44
I'm with @SamJones. It is conventional to connect the "good" battery at both terminals, and it definitely helps avoid connection problems, but you should be able to use any suitable grounding point on the "good" car in place of the battery negative post. That's what I'd try first if my car looked like yours. – mac Nov 13 '12 at 19:26
Have you tried looking around for a remote "black terminal", or another location specially labeled to show that it's intended to be used as the negative post in a jump start? Of course, there's always the friendly manual. – Iszi Nov 15 '12 at 21:42
@Iszi: There is indeed an auxiliary negative (ground) terminal lug nut in the engine chassis for this purpose. – Cory Larson Nov 30 '12 at 14:41
show 2 more comments
1 Answer
You should be able to sneak a clamp on to the positive terminal, and there's an auxiliary negative (ground) terminal lug nut to clamp onto right in front of the coolant fill tube and power steering fluid reservoir.
odysseybattery
Otherwise if you really want more room, you need to remove the intake tube (nothing to do with exhaust) by disconnecting it at the rubber snorkel attached to the throttle body. Loosen any hose clamps on it, and use some force to pry it loose the first time. It might be stubborn, but just keep wiggling!
+1 for two possible approaches and a picture. – Bob Cross Nov 30 '12 at 17:12
@BobCross: Found the picture on a forum somewhere, so can't take full credit for that :) – Cory Larson Nov 30 '12 at 19:14
