I used to travel 500 Km to my native village with a fully loaded vehicle along with 5 person in my WagonR. I also used to cruise with speed in between 80 to 100 Km/hr but the vehicle braking decrease very much in respect to only travelling with 5 person with little baggage.
Might need better tires, may need bigger brakes. Make sure you're using appropriate tires for the load and conditions. Consider trying better brake pads or possibly upgrading to a big brake kit. Perhaps better brake cooling (such as cool air ducts) would help. First you're going to have to identify the weakest component in the list so that you can upgrade it. |
Tires are going to be the biggest change you can implement. The widest, stickiest tires you can get for your conditions. Typically, any car can lock its tires up under normal conditions (average load, speeds). If it can do this, the braking system is more than adequate, and the tires are the first thing you should change. Now, when you start upgrading tires, the braking system typically starts to fall behind. Then you can worry about upgrading other braking components. If you have a heavy load, I'm betting your getting pretty good grip out of your tires, so getting better discs, calipers, etc. would be the next step. Unfortunately, this is an upgrade that's more aimed at racing enthusiasts, so finding parts suitable for street use might be difficult. |
There are a few things that you can do to gain better braking ability.
If this is a vehicle that you just bought it is possible that the brakes just aren't as good as your previous vehicle. From the information I could get online, this vehicle is equipped with drum type rear brakes. The problem may be that they are not adjusted correctly. Although the front discs do the majority of the braking ,the rear brakes must be adjusted correctly to achieve maximum braking. To an extent the rears brakes are self adjusting. There are a variety of self adjuster types from different manufacturers. Some require that you drive in reverse and apply quick pumps to the brake pedal, other require setting the park brake several times. The best self adjusters are marginal at best. The best way is to periodically have them adjusted as part of routine service. If after verifying that the brakes are working correctly you are still dissatisfied with their performance you may want to look at upgrades. The original pads were installed as a compromise of cost, noise, durability and stopping power. To stop faster you will most likely give up one or more of these characteristics. They may not last as long, they may wear rotors faster or make more noise. They certainly will cost more. Vented and drilled rotors will give better brake performance but at an increase in cost. An alternative would be to use engine braking. |
