For years I have been driving a very old car, and servicing it every 10,000 kilometres even though it took me almost a year to drive that much.
Now I have a newer car which I care about more. It's going to be doing very little kilometres -- mainly driving to/from the train station, with some driving on the weekend. I predict it will probably take me about 18 months to drive 10,000 kilometres.
Most advice I have read is that you should service your car every 10,000 kilometres OR 6 months, whichever is sooner. If I follow this advice, I will be servicing the car after only a small number of kilometres.
Given my circumstances, should I be following this advice?
The simple answer is yes - you should.
A car doing reasonable mileage may actually last longer than a car doing very low mileage, as when a car is less frequently used oils may fully drain so the next time the car is started it runs without lubrication in some areas for a short while - increasing wear. As @SamJones mentioned - checking your oil level on a weekly basis should be standard practice.
Also oils and rubber do deteriorate over time, so things like belts, wiper blades, tyre pressure etc should be checked.
I would also recommend scheduling these so that one is just before winter, as this is a good time to get pre-winter checks carried out.
This answer is very good. Just to expand on a point, I would check your engine oil level and tyre pressures once a week. As mentioned in the answer, if you're not using the car frequently then having sufficient oil and oil pressure is more important and it's always a good idea to have a quick look at the tyres if the car has been standing for a while. – Sam Jones Oct 17 '12 at 12:10
